浏览:2308 回答:3
abaqus里面曲线类型smooth step是光滑曲线吗,一般怎么用?如果选的是tablur不是smooth step会不会影响收敛性
蓝牙
table线性插值,smooth曲线,曲线公式见手册,我列了章节
2016年5月7日
蓝牙
Abaqus Analysis User's Guide 34.1.2 Amplitude curves讲的非常详细! Choose the tabular definition method (default) to define the amplitude curve as a table of values at convenient points on the time scale. Abaqus interpolates linearly between these values, as needed. By default in Abaqus/Standard, if the time derivatives of the function must be computed, some smoothing is applied at the time points where the time derivatives are discontinuous. In contrast, in Abaqus/Explicit no default smoothing is applied (other than the inherent smoothing associated with a finite time increment). You can modify the default smoothing values (smoothing is discussed in more detail below, under the heading “Using an amplitude definition with boundary conditions”); alternatively, a smooth step amplitude curve can be defined (see “Defining smooth step data” below).
2016年5月6日
奈more
@梵音静思 @蓝牙
2016年5月4日
