浏览:5145
各位前辈,我再用ANSYS 15.0的ACT做模态分析时,出现如下错误日志:The outward normal unit vector of the sloshing surface in element 1972 is not consistent with one of the global Cartesian coordinate axes. 然后计算停止,不知什么原因,请各位前辈赐教,多谢!
