报错帮助
浏览:2662 回答:1
Permeability is specified on 11774 elements but the initial void ratio is not defined. Use *initial conditions to the value. The elements are identified in element set ErrElemPermNoInitVoidRatio.
报错显示 在inp文件中输入了 /在材料属性改 还是这样报错 这应该怎么修改呀
