WB调用APDL报错?
浏览:2320
在进行瞬态分析时,想通过txt格式文本给某一点加时变载荷,但是程序可以运行,运行出来没有载荷结果,代码如下,请大佬帮忙看看。
/PREP7
*DIM, FORCELOAD, TABLE, 10,3,1
*TREAD, FORCELOAD, load, TXT, , 2
 ! 向表格FORCELOAD读入FORCELOAD.TXT文件,跳过第1行 (TIME FORCE)
/SOLU
ANTYPE,TRANS
NLGEOM,ON
SSTIF,ON
TRNOPT,FULL
OUTRES,ALL,ALL
TIMINT,ON
DELTIM,0.001,,0.001
AUTOTS,ON
KBC,0
*DO,I,1,10
TIME,I*0.001
F,RP1,FY,FORCELOAD(I,1)
CNVTOL,U,,0.03
SOLVE
*ENDDO
SOLVE$SAVE
