浏览:2438
正在做碰撞结构-热 耦合分析,但是一直报错,模型中都没有segment,不知道究竟哪里设置有问题,求助大咖帮忙分析分析
报错信息如下:
 *** Error 40390 (SOL+390)
     divide by zero in subroutine see1
     The most likely cause is a 4 noded segment with 2 nodes
     having the same coordinates.
     Look at the segment with node numbers: 11370841 11370763 11370764 11370842
     A fix is to renumber the segment connectivity
     such that the nodes with the same coordinates
     are in position 3 and 4 to form a triangle.
