ANSYS中划分网格出错? 50
浏览:2518 回答:1
用mesh画网格,运行出错,怎么解决呢
(DP 0) Summary of the simulation:
        The computation failed.
     *  Expert tool diagnostics  *
     Out of convergence disk
     The problem F.E.M. Task     has not converged.
     *  Expert tool advice in order to optimize the simulation  *
     At least one bad element has been detected in the mesh.      The worst has the following feature(s)       Too small angle in element 35986, (x,y,z) = (5.8216e-05, 0.0014438,  0.005265).
     This can lead to local inaccuracies and possibly convergence difficulties.  It is strongly recommended to fix the mesh.
狸叔VAONE
单元质量太差,可以适当做个切分再画。
2023年10月24日
评论 点赞 1
