abaqus为什么出现不满足abaqus用户手册中的材料定义的问题?
浏览:3440 回答:1
Error in job Job-1: Failed to regularize material data for material STAINLESS-STEEL. Please check your input data to see if they meet both criteria as explained in "MATERIAL DATA DEFINITION" section of the Abaqus Analysis User Manual. In general, regularization is more difficult if the smallest interval defined by the user is small compared to the range of the independent variable.
Wonderful仿真
