abaqus动力显式分析步混凝土塑性损伤模型不能适用吗?为什么会报错?
浏览:4858 回答:8
Failed to regularize material data for material C-FCK25. Please check your input data to see if they meet both criteria as explained in "MATERIAL DATA DEFINITION" section of Abaqus Analysis User Manual. In general, regularization is more difficult if the smallest interval defined by the user is small compared to the range of the independent variable.
Abaqus/Explicit Packager exited with an error - Please see the  status file for possible error messages if the file exists.
fengmo2194184
cdp可以在动态显式求解中适用的
2021年5月13日
北望逸尘
应该是你的数据出了问题,可以帮你看看
2021年5月12日
评论 5 点赞
