abaqus运行出行错误,怎么解决? 100
浏览:3306 回答:2
the problem is too large to run with abaqus. typically this caused by the existence of a very large element such as a substructure with a large number of retained dof. a large cavity in a cavity radiation problem, or surface-based coupling with a large number of coupling nodes.
