THE PROBLEM IS TOO LARGE TO RUN WITH Abaqus?
浏览:4972 回答:2
Error in job Job-2: THE PROBLEM IS TOO LARGE TO RUN WITH Abaqus. TYPICALLY THIS IS CAUSED BY THE EXISTENCE OF A VERY LARGE ELEMENT SUCH AS A SUBSTRUCTURE WITH A LARGE NUMBER OF RETAINED DOF, A LARGE CAVITY IN A CAVITY RADIATION PROBLEM, OR SURFACE-BASED COUPLING WITH A LARGE NUMBER OF COUPLING NODES.
Job Job-2: Analysis Input File Processor aborted due to errors.
Error in job Job-2: Analysis Input File Processor exited with an error - Please see the  Job-2.dat file for possible error messages if the file exists.
Job Job-2 aborted due to errors.
abaqus计算一模型,提示错误为The PROBLEM IS TOO LARGE TO RUN WITH Abaqus?有小伙伴知道哪里出错了吗
