lsdyna运行问题,已经更换成16g内存,但是还有这个问题? 20
浏览:3108 回答:3
*** Error 70021 (OTH+21) Memory is set 2921091 words short memory size 20000000 Increase the memory size by one of the following where #### is the number of words requested: 1) On the command line set - memory=#### 2) In the input file define memory with *KEYWORD i.e., *KEYWORD #### or *KEYWORD memory=####
浩雨
