ABAQUS XFEM为什么预制多条水力裂缝总是报错? 50
浏览:2902 回答:5
在Interaction模块中,Special->Crack->XFEM预制多条裂缝,系统总是出现如下警告:
The following XFEM cracks are failing to correctly generate. The error conditions are listed with the crack names: Crack-1 - Multiple intersections between crack and an element edge.
这是什么原因?哪一步操作错误了吗?重新操作一次还是报错,求大神指点!#ABAQUS#
