Time increment required is less than the minimum?
浏览:4648 回答:8
ABAQUS初学者,刚开始学钢筋混凝土的粘结滑移,通过修改inp文件设置非线性弹簧,运行出现了以下错误,请问怎么解决?附inp文件,恳求各位大佬帮看一下,谢谢谢谢谢
Time increment required is less than the minimum specified
The analysis has been terminated due to previous errors. All output requests have been written for the last converged increment.
Abaqus/Standard Analysis exited with an error - Please see the message file for possible error messages if the file exists.
