abaqus导入应力计算报错,怎么改还是不对,希望哪位老师帮着看一下什么原因? 70
浏览:2561 回答:1
错误如下
Error in job Job-1: The volume of 3 elements is zero, small, or negative. Check coordinates or node numbering, or modify the mesh seed. In the case of a tetrahedron this error may indicate that all nodes are located very nearly in a plane. The elements have been identified in element set ErrElemVolSmallNegZero.
Job Job-1: Analysis Input File Processor aborted due to errors.
Error in job Job-1: Analysis Input File Processor exited with an error.
Job Job-1 aborted due to errors.
就想知道什么原因以及怎样修改
郑钧 Adam
