Node set assembly_m_set-4 has no members and will be ignored? 20
浏览:2525
请问各位大佬abaqus中提示Node set assembly_m_set-4 has no members and will be ignored. Nodes defined in this set may have been deleted because they were not connected to any elements是什么原因啊,该怎么改呢?
