经Hypermesh分网导入ABAQUS提交计算报错,出现如下问题? 50
浏览:2724 回答:1
Normal cannot be computed in 1 elements. The nodal coordinates may be incorrect or the element aspect ratio may exceed 1000 to 1. The elements have been identified in element set ErrElemNormal.
Error in defining normal to the element surface at a node in 1 elements. The elements have been identified in element set ErrElemShellNormal.
Analysis Input File Processor exited with an error.
谢谢各位大神解答
SnowWave02
