ANSYS 做时程地震动考虑自重时一直出错? 20
浏览:2097
请问大神,做了一个导管架结构,后面时程地震动并考虑自重的命令流如下,输入一直出错怎么破
/SOLU
ALLSEL
ANTYPE,TRANS
TRNOPT,FULL
TIMINT,OFF
NLGEOM,ON
TIME,1E-8
NSUBST,2
KBC,1
NSEL,S,LOC,Z,-50
D,ALL,ALL
ALLSEL
ACEL,0,0,9.8
SOLVE
TIMINT,ON
*SET,NT,1000
*SET,DT,0.01
*DIM,X_INPUT,ARRAY,NT,1,1, , ,
*CREATE,ansuitmp
*VREAD,X_INPUT,'qianan-seis_wave_ew_0.01_10','txt'
(F8.3)
*END
/INPUT,ansuitmp
ALPHAD,0.1575
BETAD,2.5389E-03
*DO,I,1,NT
TIME,I*DT
ACEL,X_INPUT(I),0,0
KBC,1
NSUBST,1
OUTPR,ALL,NONE
OUTRES,ALL,NONE
OUTRES,NSOL,ALL
SOLVE
*ENDDO
FINISH
