abaqus警告!!!请问提示下面这段话是哪里有问题啊
浏览:7437 回答:4
For two-dimensional models, if a non-unity thickness is specified for two-dimensional solid elements and these elements are involved in an interaction such as contact, the same thickness should be specified for the out-of-plane thickness of the corresponding surface under *surface interaction.
北望逸尘
