abaqus的embedded约束?
浏览:2688 回答:3
我在建立地下隧道盾构管片的模型,管片采用三维实体单元建模,但是为了简化,管片间的螺栓使用的是二维桁架单元简化,桁架单元会斜穿两个面,一直计算不收敛,然后报这个警告For two-dimensional models, if a non-unity thickness is specified for two-dimensional solid elements and these elements are involved in an interaction such as contact, the same thickness should be specified for the out-of-plane thickness of the corresponding surface under *surface interaction.是哪里设置有问题或者讲究吗?
北望逸尘
