ANSYS常用命令[超完善版].doc
2023-02-10 下载:122
下载
大小:3.93MB
ANSYS常用命令 word版本
  -1:布尔操作失败时产生一个错误信息
如果Lab=VERSION,其值有:
  RV52:激活5.2版本兼容性选项;
RV51:激活5.1版本兼容性选项;
3.1.2 BTOL, PTOL
Specifies the Boolean operation tolerances.
指定布尔操作的容差
Main Menu>Preprocessor>Modeling>Operate>Booleans>Settings
PTOL :Point coincidence tolerance.
节选段落二:
See the ANSYS Modeling and Meshing Guide for an illustration. See the BOPTN command for the options available to Boolean operations.
节选段落三:
See the ANSYS Modeling and Meshing Guide for an illustration. See the BOPTN command for an explanation of the options available to Boolean operations.
