请问abaqus提交任务后出现这个error怎么解决?
浏览:2246 回答:5
"C:\data\model\4945\task\11256\run_11201\84939_BDF-R6-SPRING_13028" to be used for scratch files. Please check that the value of the "scratch" parameter is a valid directory and has write permission.
更换具有写入权限的临时文件夹即可:edit job-scratch directory
临时文件有问题。
