模态分析 无质量阵错误请问各位大神如何解决?
浏览:2205 回答:1
报错信息
Error in job Job-1: THERE ARE NO ELEMENTS WITH MASS MATRICES IN THE MODEL. THE FREQUENCY EXTRACTION CANNOT BE DONE. IF THIS IS A RESTART JOB, MAKE SURE THAT THE OLD JOB CONTAINS "*RESTART, WRITE"
