关于dyna出现的警告?Segment based contact stiffiness?
浏览:2018
 求助
 进行计算时,出现警告 Segment based contact stiffiness was reduced due to an increasing solution time step.The new step for the stiffiness calculation is 6.7658E-02?   这是由于什么导致的呀?
