Abaqus中B31梁单元无法混凝土塑性损伤模型?
浏览:3688 回答:4
如题,使用做一个框架的抗震分析,梁柱均采用B31单元,混凝土使用C30损伤模型,但报错The *concrete damaged plasticity option is not available for beam-type elements with shear stress。换成最简单的悬臂梁模型,相同的材料本构仍然报错。查询软件说明书,有这样一句话:ABAQUS offers a variety of elements for use with the concrete damaged plasticity model: truss, shell, plane stress, plane strain, generalized plane strain, axisymmetric, and three-dimensional elements. Most beam elements can be used; however, beam elements in space that include shear stress caused by torsion (i.e., not thin-walled, open sections) and do not include hoop stress (i.e., not PIPE elements) cannot be used.。说明B31梁单元无法使用损伤模型吗?但看了很多论文都是明确指出二者可以共同使用的,求高手解释!!
另附inp文件。
Abaqus中B31梁单元无法混凝土塑性损伤模型?的图1Simple_CantileverBeam_1.zip
😂😉_8005
我也在做这个请问你解决了么?
2022年5月15日
T10
您好,我的课程里面讲解了利用B31梁单元来做三维框架结构,包含了时程分析以及pushover分析,当然框架里面是配有钢筋的。
2019年6月18日
无尾猴
2017版说明书里这样写:Abaqus offers a variety of elements for use with the concrete damaged plasticity model: truss, shell, plane stress, plane strain, generalized plane strain, axisymmetric, and three-dimensional elements. Most beam elements can be used; however, beam elements in space that include shear stress caused by torsion and do not include hoop stress (such as B31, B31H, B32, B32H, B33, and B33H) cannot be used.。明确指出B31单元无法使用,那我看的论文里是怎么算的啊?难道老版本允许吗。论文为:上海中心大厦抗震性能分析和振动台试验研究_蒋欢军
另附论文截图:
2019年4月2日
评论 2 点赞
