程序中用到了map函数,现在想把map函数得到的结果保存到文件中,应该怎么编程? 20
浏览:1795
程序中用到了map函数,现在想把map函数得到的结果保存到文件中,应该怎么编程(自己写的程序报错了)
#include<stdio.h>
#include<stdlib.h>
#include<math.h>
#include <map>
using namespace std;
map<float,float> g_mapData;
FILE *fp = NULL;
void insert_map(float jie1,float jiao1)
        if (g_mapData.find(jiao1) != g_mapData.end() )
                float jie = g_mapData[jiao1];
                g_mapData[jiao1] = jie + jie1;
        }else
                g_mapData[jiao1]= jie1;
void print_map()
        FILE *fp = NULL;
        printf("打印全部\n"程序中用到了map函数,现在想把map函数得到的结果保存到文件中,应该怎么编程?的图2;
        map<float,float>::iterator it=g_mapData.begin();
        for(;it!=g_mapData.end();++it)
                printf("%lf:%lf | ",it->first,it->second);
                printf("\n end \n"程序中用到了map函数,现在想把map函数得到的结果保存到文件中,应该怎么编程?的图3;
        fp = fopen("test.txt", "a"程序中用到了map函数,现在想把map函数得到的结果保存到文件中,应该怎么编程?的图4;
    fprintf(fp, "%2.5f\n", it->first,it->second);
    fclose(fp);
int main()
int n;
double a,b,c,d,e,f,jit,ji1,sum,jiw,xiangliangx,xiangliangy,zongjiao;
sum=0;
jiw=0;
while(1)
        printf("请输入坐标及两半径\n"程序中用到了map函数,现在想把map函数得到的结果保存到文件中,应该怎么编程?的图5;
        scanf("%lf%lf%lf%lf%lf%lf",&a,&b,&c,&d,&e,&f);
        double x=fabs(a-c);
        double y=fabs(b-d);
        double j=sqrt(x*x+y*y);
        double h=e+f;
        if(j<h)
        double A;
        A=(e*e+j*j-f*f)/(2*j*e);
        double ji=0;
        ji=acos(A);
        ji=ji/3.1415926*180;
        int jir=int(ji);
        ji=jir;
        jit= ji/180*3.1415926;
        n=ji/0.1;
        printf("与第一个圆的夹角%lf\n",ji);
        xiangliangx=c-a;
        xiangliangy=d-b;
        if(xiangliangy>0)
          if(xiangliangx>0)
                  zongjiao=atan(xiangliangy/xiangliangx);
          else
                  zongjiao=atan(-xiangliangy/xiangliangx)+3.1415926/2;
        else
           if(xiangliangx>0)
          else
                  zongjiao=atan(-xiangliangy/xiangliangx)-3.1415926/2;
         zongjiao = int(zongjiao/3.1415926*180);
         zongjiao=zongjiao/180*3.1415926;
        for(int i=1;i<n;i++)
         double x1,x2,x3,jieg1,jieg2,jieg,B,jie0,jie1,jiao1,jiao2,jiao;
        B=jit/n;
        x1=1+tan(i*B)*tan(i*B);
        x2=-2*j;
        x3=j*j-f*f;
        jieg1=(-x2+sqrt(x2*x2-4*x1*x3))/(2*x1);
        jieg2=jieg1*tan(i*B);
        jieg=sqrt(jieg1*jieg1+jieg2*jieg2);
        jie0=(jieg-2);
        jiao1=(zongjiao+B*i)/3.1415926*180;
        jiao2=(zongjiao-B*i)/3.1415926*180;
        jiao=i*B/3.1415926*180;
        jie1=pow(jie0,1.5)*cos(i*B)*f;
        sum=sum+jie1;
        printf("输出A%d=%lf\n",i+1,jie1);
        printf("输出角A%d=%lf\n",i+1,jiao1);
        printf("输出角A%d=%lf\n",i+1,jiao2);
        insert_map(jie1,jiao1);
        else
        printf("两圆无交点"程序中用到了map函数,现在想把map函数得到的结果保存到文件中,应该怎么编程?的图6;
        print_map();
printf("输出:%lf\n",sum);
system("pause"程序中用到了map函数,现在想把map函数得到的结果保存到文件中,应该怎么编程?的图7;
return 0;
