star-ccm与abaqus联合仿真?
浏览:3781 回答:1
我的star-ccm是12.06版本,abaqus是2017版本。在做star-ccm里面“Abaqus Co-Simulation: Mechanical Coupling”的例子,提交计算的时候一直报错。麻烦大神看一下我的路径设置是否正确。另外“abaqus执行”里面的可执行名称应该怎么填,我写的 abaqus 。下面是错误提示
Abaqus installation directory: \Program Files\Dassault Systemes\SimulationServices\V6R2017x\win_b6492
SIMULIA_CSE_LIBPATH: C:\SIMULIA\CAE\2017\win_b64
Loading the SIMULIA Co-Simulation Engine shared libraries failed.
In order for STAR-CCM+ to automatically locate the libraries, check
the following:
 - if the executable name is set to an Abaqus command, the command
   must be in the system path (the path cannot be prepended to the
   command);
 - if specifying the full path to the Abaqus executable, the path
   must point to the Abaqus installation directory;
 - if standalone co-simulation libraries are to be used in place of
   the libraries provided with the Abaqus installation, the
   SIMULIA_CSE_LIBPATH environment variable must be set to the
   standalone library installation path.
Alternatively, the library path may be explicitly specified in Linux
with the STAR-CCM+ -ldlibpath launch option or in Windows via the system
path.
初学者123
可执行名称里面输入abaqus启动的地址,比如C:\SIMULIA\Abaqus\Commands\abq6141.bat
2020年12月25日
