节点过约束怎么解决? 20
浏览:4043 回答:4
我在模拟基坑开挖时,围护结构地连墙底面与土用tie的连接,运行时出现错误:1 nodes are used more than once as a slave node in *TIE keyword. These constraints are not removed either due to the presence of *CONSTRAINT CONTROLS,NO CHANGES keyword or because removing the constraints might affect the model. The nodes have been identified in node set ErrNodeOverconTieSlave.
4 *TIE dependent nodes have specified boundary conditions. Their associated *TIE independent nodes have, however, conflicting boundary conditions. Please resolve these conflicting boundary conditions. The *TIE dependent and independent nodes have been identified in node set WarnNodeOverconBoundTieInc.
Analysis Input File Processor exited with an error.
辅节点重复使用了,或者在辅节点上施加了约束。
可以更新其中一个*TIE,不选择那个节点
