ABAQUS新手,温度场模拟出现问题,求大神解答?
浏览:1602 回答:2
求大神解答,软件小白伤不起
具体情况如下:先出现警告history output is not requested in the following steps:transit heat transfer,steady heat transfer
然后提交后失败出现Problem during compilation - D:\tem\1+1.for
log显示Aborted:   job aborted due to error(s).
ABAQUS新手,温度场模拟出现问题,求大神解答?的图1
ABAQUS新手,温度场模拟出现问题,求大神解答?的图2
