关于橡胶材料密封圈计算不收敛问题的求问
浏览:2240
  包含橡胶材料密封圈的模型,求解时出现“Material rubber has an active Hyperelastic property and large deflection is not being considered.Please either:a)Go to analsis settings details and turn large deflection"on" b)go to engineering data and suppress hyperelastic material properties”,这样的问题,并且根据提示,也打开了大变形,还是出错,请问有什么办法可以解决这样的问题吗?
