ABAQUS模拟基坑开挖时刚开始运行就中断,求教? 50
浏览:1892 回答:1
模拟的深基坑尺寸:666m*352m,深26米,土分四层,支护结构简化为四周均是地下连续墙。
这是中断后的错误信息:The memory allocated to process constraint is not adequate. Set the environment variable aba_scale_std_contact_connectivity to a value larger than 1.0 and rerun the analysis.
Abaqus/Standard Analysis exited with an error - Please see the  message file for possible error messages if the file exists.
