simufact.welding 中出现 aborted with exit 1009,请老师指教? 70
浏览:2466 回答:1
9999 1009
Error encountered in stress recovery. The output will reveal
which element has a particular problem. The error is usually
due to excessive deformation in the element. Note that this
can occur during the iterative process, so that it is not
always possible to visualize the excessive deformation.
Check the material behavior and the magnitude of the
incremental loads.
Suggestion :
Activate the cut-back feature if using the AUTO LOAD, AUTO
STEP or AUTO INCREMENT solution schemes. This will allow the
analysis to automatically cut down the time step and to try
again from the end of the last converged increment. For the
AUTO LOAD procedure, the increment numbers are maintained as
specified in the input.
Hey_蛮
请问解决了吗
2023年10月12日
