openfoam1712版本中一些问题? 50
浏览:1742
 想请问一下,在OpenFoam1712版本中tutorials/multiphase/interFoam/RAS/waterChannel/0文件里面的s字典是是什么物理量?我想计算波浪问题,加入kwsst模型,s字典有什么影响吗?对于规则波一般在多少秒才能达到稳定?我阅读别人的文献一般只在30+s就稳定,我计算的要达到80+秒才稳定。
http://ihfoam.ihcantabria.com/source-download/     ihfoam官网,官网中写道下面这一段话
As The Environmental Hydraulics Institute IHCantabria is an official contributions to OpenFOAM-v1612+  and OpenFOAM-1706, IHFOAM has become a part of the official release by OpenCFD (http://www.openfoam.com/). Therefore, once you download and install OpenFOAM in your computer, you will find the boundaries conditions and some tutorials.
在网上有人说openfoam1712版本中已经嵌入ihfoam模块,但是我在该版本中没有找到相对应的算例及相关内容?想请问一下具体是怎么回事
