abaqus齿轮接触啮合?
浏览:1904
For contact pair,adjustment was specified but no node was adjusted more than the adjustment distance=2.22e-16.
指定了调整,但没有调整节点大于调整距离=2.22E-16。
这是怎么回事,应该怎么解决
