ANSYS Workbench瞬态动力学分析?
浏览:2043 回答:1
An internal solution magnitude limit was exceeded. Please check your Environment for inappropriate load values or insufficient supports.Also check that your mesh has more than 1 element in at least 2 directions if solid brick elements are present.请问分析过程中老是报这样的错误是怎么回事呢?
技术邻问答
@yunduan082 @雷正升
2018年5月25日
已采纳 评论 点赞
