ANSYS疲劳结果如何保存与输出?
浏览:1759
ANSYS计算疲劳后结果如下,因为要计算很多节点,想把每个节点的疲劳因子(CUMULATIVE FATIGUE USAGE)存入一个数组。看help中说
Fatigue calculation results are printed in the output. If you have routed your output [/OUTPUT] to a file (for example Jobname.OUT), then you can review the results by listing that file。
但不知道如何实现,求大神们给命令流。
