flac3d fish语言中出现如下报错,如何修改?
浏览:4523
在技术邻网站上根据乔成前辈改的删除link的fish语言,可是刚开始就报错了,希望各位老师能够解答一下,谢谢
def _createLink
    _pon=nd_near(20,2,16)
    _pileID=nd_id(_pon)
    _ponl=nd_link(_pon)
    if _ponl # null then
       _linkID=lk_id(_ponl)
       command
          sel delete link range id _linkID
       end_command
    end_if
end
输入后,FLAC报错:
*** Bad conversion of parameter number 6 (_linkID).
Expected tokens:
     unsigned long >= than 1
    From line 8 of source C:/Users/asus/Desktop/slope/structure-auto-link1.txt.
