hyperworks拓扑优化约束条件失效? 60
浏览:1576
                           RETAINED RESPONSES TABLE
Response Type  Response    Subcase Grid/     DOF/   Response     Objective    Viol.
User-ID          Label     /RANDPS Element/  Comp     Value      Reference/     %
                           /Model  MID/PID/  /Reg                Constraint
                           +Frqncy Mode No.                        Bound
       5 EQATN wfreq             1       --    --   1.854E+01 MAX
       1 MASS  mass             --       --  TOTL   1.224E+01  >  1.240E+01    1.3 V
       1 MASS  mass             --       --  TOTL   1.224E+01  <  1.250E+01    0.0
请问红字部分如何理解?为何明明已经超过了约束条件却仍然是大于号?
下面是初始步,可以发现初始状态质量确实在约束条件范围内。
       5 EQATN wfreq             1       --    --   1.507E+01 MAX
       1 MASS  mass             --       --  TOTL   1.240E+01  >  1.240E+01    0.0 A
       1 MASS  mass             --       --  TOTL   1.240E+01  <  1.250E+01    0.0 A
