使用cfx模拟出错,求教原因? 70
浏览:3631 回答:1
提示The ANSYS CFX solver exited with return code 1.   No results file has been created.求教什么原因
 ERROR #002100048 has occurred in subroutine SU_BNEXT.              |
 | Message:                                                           |
 | All vertices for a fluid domain lie on boundaries.  This is        |
 | considered to be a fatal error because control volume gradients    |
 | cannot be calculated, leading to serious discretization error.     |
 | A common cause for this error is a mesh which is only one          |
 | element thick, without symmetry or 1:1 periodicity on the lateral  |
 | boundaries.  If you have this situation, and the domain is         |
 | two-dimensional, please change the lateral boundary conditions     |
 | to symmetry or 1:1 periodicity.  Alternatively, for                |
 | three-dimensional simulations, please ensure that your mesh        |
 | has at least two elements across.                                  |
 | Execution is terminating.  This error message can be bypassed by   |
 | setting the expert parameter 'boundary vertex check = f', but      |
 | be aware that doing so may lead to sigificant solution error.
张哲
顶一下
2018年3月6日
