Abaqus温度场模拟中出现低于绝对零度,如何解决? 50
浏览:3062 回答:3
Abaqus温度场模拟中出现如下错误:Temperature at 1 nodes has fallen below absolute zero. Increment will be attempted again with a new time increment. The nodes have been identified in node set WarnNodeTempBelowZeroStep3Inc25.该怎么解决
