如何查看warnNodeOverconTieSlave? 50
浏览:4159 回答:3
在ABAQUS中,在job中运行data check ,出现abort,许多节点出现了问题,
199 nodes are used more than once as a slave node in *TIE keyword. One of the *TIE constraints at each of these nodes have been removed. The nodes have been identified in node set WarnNodeOverconTieSlave.
75 elements are distorted. Either the isoparametric angles are out of the suggested limits or the triangular or tetrahedral quality measure is bad. The elements have been identified in element set WarnElemDistorted.
,如何查看这些节点set,这个问题只是举例,我只是想知道以后如何查找data check abort后节点set如何查看
Kerry
后处理查看。 Visualization模块,display group manager--creat--找到报错的set 同时勾选右下的highlight items in viewport 就可以看到报错的单元或者节点
2018年1月5日
评论 点赞 1
技术邻问答
如果觉得回答对你有帮助,请记得及时采纳哦
2018年1月8日
小月
打开odb,根据节点编号查
2018年1月5日
