abaqus中无论怎样修改都出现 WarnNodeMissMasterIntersect,怎么破? 100
浏览:7573 回答:3
各位abaqus的大神们,在创建interaction中的tie的时候老是出现
**** nodes are either missing intersection with their respective master surface or are outside the adjust zone。以及The distance from the master surface is greater than the position tolerance value。
问题1:怎么查看The distance from the master surface is greater than the position tolerance value
问题2:如何修改如图2该种情况,简历合适的
易炜
