abaqus提交提示错误? 30
浏览:4239 回答:5
A redundant contact condition has been specified. The redundancy involves the contact pair referencing surfaces assembly_surf-base1-bolt and assembly_surf-bolt-base and the contact pair referencing surfaces assembly_surf-base2-bolt and assembly_surf-bolt-base.
A redundant contact condition has been specified. The redundancy involves the contact pair referencing surfaces assembly_surf-base3-bolt and assembly_surf-bolt-base and the contact pair referencing surfaces assembly_surf-base4-bolt and assembly_surf-bolt-base.
Analysis Input File Processor exited with an error.
