abaqus提示错误? improperly defined surface(s).? 200
浏览:11597 回答:11
4 improperly defined surface(s). Please check your surface definitions. Make sure that all surface normals point outward.
Abaqus/Explicit Packager exited with an error - Please see the status file for possible error messages if the file exists.
这种错误应该从哪下手解决呢?怎么在abaqus里面查看surface normals?谢谢
且听凤吟
