求助:Fluent中导入UDF
浏览:3533 回答:2
#include "udf.h"
#include "math.h"
FILE *result;
DEFINE_EXECUTE_AT_END(pressure_end)
    result=fopen("Pressure_GET.txt","a");
    Domain *d
    d=Get_Domain(1);
    Thread *t;
    cell_t c;
    real pressure;
    real A[ND_ND];
    real point_x;
    real point_y;
    real point_z;
    real Y=2.5;
    real R=6.;
    int curr_ts;
    curr_ts=N_TIME;
    thread_loop_c(t,d)
           if(curr_ts>=720)
               real X=(-1.)*R *sin(2.*curr_ts);
               real Z=(-1.)*R *cos(2.*curr_ts);
           begin_c_loop(c,t)
                C_CENTROID(A,c,t);
                point_x=A[0];
                point_y=A[1];
                point_z=A[2];
            if(fabs(point_x-X)<=0.0001&&fabs(point_y-Y)<=0.0001&&fabs(point_z-Z)<=0.0001)
                pressure=C_P(c,t);
                fprintf(result,"坐标:%12.8f%12.8f%12.8f,时间步数:%f\n", point_x,point_y,point_z,curr_ts);
                fprintf(result,"%12.8f\n", pressure);
            end_c_loop(c,t)
        fclose(result);
导入Fluent中时,出现错误:
F:\\VAWT Simulation\\try hard\\fluent\\Pressure_GET2.c:2: math.h: No such file or directory
Error: F:\\VAWT Simulation\\try hard\\fluent\\Pressure_GET2.c: line 7: parse error.
Error: F:\\VAWT Simulation\\try hard\\fluent\\Pressure_GET2.c: line 9: parse error.
Error: F:\\VAWT Simulation\\try hard\\fluent\\Pressure_GET2.c: line 10: parse error.
Error: F:\\VAWT Simulation\\try hard\\fluent\\Pressure_GET2.c: line 11: parse error.
Error: F:\\VAWT Simulation\\try hard\\fluent\\Pressure_GET2.c: line 12: parse error.
Error: F:\\VAWT Simulation\\try hard\\fluent\\Pressure_GET2.c: line 13: parse error.
Error: F:\\VAWT Simulation\\try hard\\fluent\\Pressure_GET2.c: line 14: parse error.
Error: F:\\VAWT Simulation\\try hard\\fluent\\Pressure_GET2.c: line 15: parse error.
Error: F:\\VAWT Simulation\\try hard\\fluent\\Pressure_GET2.c: line 16: parse error.
Error: F:\\VAWT Simulation\\try hard\\fluent\\Pressure_GET2.c: line 17: parse error.
Error: F:\\VAWT Simulation\\try hard\\fluent\\Pressure_GET2.c: line 18: parse error.
Error: F:\\VAWT Simulation\\try hard\\fluent\\Pressure_GET2.c: line 19: curr_ts: undeclared variable
它提示错误的是这几行:
  #include "math.h"
   Domain *d
    d=Get_Domain(1);
    Thread *t;
    cell_t c;
    real pressure;
    real A[ND_ND];
    real point_x;
    real point_y;
    real point_z;
    real Y=2.5;
    real R=6.;
    int curr_ts;
    curr_ts=N_TIME;
全是定义行出错,这是因为什么原因啊?一直卡在这儿两天了,求助大神们!!
路修在戈壁滩上
已解决
2017年10月19日
