做fluent udf时,导入程序(.c文件),出现这个警示条,求助什么原因,多谢
浏览:4225 回答:2
The UDF library you are trying to load (C:\Users\o\AppData\Local\Temp\check_valve_diffusion_3d.tmp1\check_valve_diffusion_3d_files\dp0\FFF\Fluent\libudf) is not compiled for 3d on the current platform (win64).
系统找不到指定的文件。
C:\Users\ao\AppData\Local\Temp\check_valve_diffusion_3d.tmp1\check_valve_diffusion_3d_files\dp0\FFF\Fluent\C:\Users\ao\AppData\Local\Temp\check_valve_diffusion_3d.tmp1\check_valve_diffusion_3d_files\dp0\FFF\Fluent\libudf\win64\3d\libudf.dll
