Abaqus螺栓连接仿真时报错,施加预紧力时可能存在过约束,想请教下大家? 20
浏览:5878 回答:14
如图,结构设计用到螺栓连接,结构的强度等性能是否符合设计要求。螺栓做了简化。
接触设置:螺栓、螺母与上、下板接触采用的surface to surface contact,板之间也采用surface to surface ,螺柱与孔内表面采用tie连接。
预紧力施加:在螺柱之间切出一个平面,施加bolt-load。
28 nodes may not be used with a multi-point constraint since they are also part of pretension section. The nodes have been identified in node set ErrNodeMPCPretenSec.
Analysis Input File Processor exited with an error.
