abaqus做单轴压缩的弯扭耦合层合板的屈曲,出现的问题?
浏览:2426 回答:2
最后提交作业时,出现中断,然后错误,给的信息时下面的英文,求大神帮帮忙,就差这一点了,谢谢了
The lanczos solver cannot be used for buckling analysis in which a model: (1) is preloaded above the bifurcation (buckling) load, or; (2) has rigid body modes, or (3) is overconstrained or (4) contains hybrid elements or connector elements.
林ads
模型发给我看看,QQ442122028
2017年4月26日
