下面的命令流进行静力分析,求解时既不出现solution is done也不出现错误,原因是什么?
浏览:1736 回答:8
finish
/clear,all
/PREP7
ET,1,PIPE288
SECTYPE,1,PIPE, ,
SECDATA,32,1.8,0,0,1,0,0,0,
SECOFFSET,0,0,
SECCONTROL,0,
MP,EX,1,2.1e11
MP,PRXY,1,0.3
K,1,-4000,0,0,
K,2,-3736,1500,0,
K,3,-3449,1800,0,
K,4,-3225.6,1999,0,
!K,5,-1919,2850,0,
K,6,-2036,2797.6,0,
K,7,-1253.4,3125.7,0,
K,8,0,3400,0,
K,9,1253.4,3125.7,0,
!K,10,1919,2850,0,
K,11,2036,2797.6,0,
K,12,3225.6,1999,0,
K,13,3449,1800,0,
K,14,3736,1500,0,
K,15,4000,0,0,
K,17,0,1999,0,
LSTR,1,2
LSTR,14,15
LARC,2,8,6
LARC,14,8,11
LSEL,S,,,1,4,1
LATT,1, ,1, , , ,1
LESIZE,ALL, , ,30, ,1, , ,1,
lmesh,1,4,1
ET,2,LINK180
MP,EX,2,2.1e11
MP,PRXY,2,0.3
SECTYPE,2, BEAM, CTUBE, , 0
SECOFFSET, CENT
SECDATA,30.5,32,0,0,0,0,0,0,0,0,0,0
R,2,294.524, ,0
n,122,-3225.6,1999.0,0.0000
n,124,-3010.6,1999.0,0.0000
n,125,-2795.5,1999.0,0.0000
n,126,-2580.5,1999.0,0.0000
n,127,-2365.4,1999.0,0.0000
n,128,-2150.4,1999.0,0.0000
n,129,-1935.4,1999.0,0.0000
n,130,-1720.3,1999.0,0.0000
n,131,-1505.3,1999.0,0.0000
n,132,-1290.2,1999.0,0.0000
n,133,-1075.2,1999.0,0.0000
n,134,-860.16,1999.0,0.0000
n,135,-645.12,1999.0,0.0000
n,136,-430.08,1999.0,0.0000
n,137,-215.04,1999.0,0.0000
n,123,3225.6,1999.0,0.0000
n,138,-0.22737E-12,1999.0,0.0000
n,139,215.04,1999.0,0.0000
n,140,430.08,1999.0,0.0000
n,141,645.12,1999.0,0.0000
n,142,860.16,1999.0,0.0000
n,143,1075.2,1999.0,0.0000
n,144,1290.2,1999.0,0.0000
n,145,1505.3,1999.0,0.0000
n,146,1720.3,1999.0,0.0000
n,147,1935.4,1999.0,0.0000
n,148,2150.4,1999.0,0.0000
n,149,2365.4,1999.0,0.0000
n,150,2580.5,1999.0,0.0000
n,151,2795.5,1999.0,0.0000
n,152,3010.6,1999.0,0.0000
n,153,-1253.4,3125.7,0.0000
n,154,0.0000,1999.0,0.0000
n,156,-1169.8,3050.6,0.0000
n,157,-1086.3,2975.5,0.0000
n,158,-1002.7,2900.4,0.0000
n,159,-919.16,2825.2,0.0000
n,160,-835.60,2750.1,0.0000
n,161,-752.04,2675.0,0.0000
n,162,-668.48,2599.9,0.0000
n,163,-584.92,2524.8,0.0000
n,164,-501.36,2449.7,0.0000
n,165,-417.80,2374.6,0.0000
n,166,-334.24,2299.5,0.0000
n,167,-250.68,2224.3,0.0000
n,168,-167.12,2149.2,0.0000
n,169,-83.560,2074.1,0.0000
n,184,1253.4,3125.7,0.0000
n,186,1169.8,3050.6,0.0000
n,187,1086.3,2975.5,0.0000
n,188,1002.7,2900.4,0.0000
n,189,919.16,2825.2,0.0000
n,190,835.60,2750.1,0.0000
n,191,752.04,2675.0,0.0000
n,192,668.48,2599.9,0.0000
n,193,584.92,2524.8,0.0000
n,194,501.36,2449.7,0.0000
n,195,417.80,2374.6,0.0000
n,196,334.24,2299.5,0.0000
n,197,250.68,2224.3,0.0000
n,198,167.12,2149.2,0.0000
n,199,83.560,2074.1,0.0000
TYPE,2
MAT,2
SECNUM,2
REAL,2
e,122,124
*do,i,0,27,1
e,124+i,125+i
*enddo
e,152,123
e,153,156
*do,i,0,12,1
e,156+i,157+i
*enddo
e,169,138
e,184,186
*do,i,0,12,1
e,186+i,187+i
*enddo
e,199,138
allsel,all
FINISH
/SOL
D,1, , , ,0,UX,UY,uz, , , ,
D,33, , , ,0,UX,UY,uz, , , ,
F,66,FY,-130
F,95,FY,-130
F,79,FY,-170
F,108,FY,-170
F,63,FY,-190
ALLSEL,ALL
/STATUS,SOLU
NLGEOM,1
SOLVE
FINISH
(4)
Barnettt
我通过接点自由度耦合想把中间的杆件和外侧杆件联系起来可以吗,网上这么说行,但是我做的还是没有联系到一起
2017年4月21日
邹正刚
你这还是以前那个老问题呀。 以前的问题,中间三根杆与外围两根长杆没有连接到一起的问题解决了吗? 这次还是是约束不足。你可以为材料添加密度,然后做一次模态分析,抽取 10 个模态,看看是否有零频率。如果有零频率,则显示一下各零频率的模态形状,分析一下缺少什么约束。
2017年4月21日
邹正刚
你打开了大变形选项,则问题属于非线性分析。但是你的求解设置基本没有。至少需要设置一下求解的子步数、加载方式、自动时间步等。 另外,计算结束,无论是否正常结束,都可以看一下输出窗口和错误文件,看看有什么信息。如有警告或错误信息,可以分析原因,解决问题。
2017年4月21日
评论 4 点赞
技术工
@ANSYS专家 @水哥ANSYS @张小
2017年4月20日
