abaqus如何关闭速度监测?
浏览:3808 回答:9
The ratio of deformation speed to wave speed exceeds 1.0000 in at least one element. This usually indicates an error with the model definition. Additional diagnostic information may be found in the message file.
各位老师,在abaqus计算时出现如上错误,该怎么解决。初步认定是加载速度过大,但就是这么大,是否可以关闭速度监测,怎么关闭呢?谢谢
