ABAQUS桩土接触
浏览:3535 回答:4
桩侧与土侧采用摩擦约束,桩底和土底采用tie约束,计算地应力时,第一步就不收敛,警告信息里全是
If significant clearance/overclosure exists between surface pair (assembly__t45_anpo-1-2_sn,assembly__t45_anpo-1-2_m) and the master surface does not have rotational degrees of freedom, adjustment is recommended for correct enforcement of the tie constraint
Slave surface assembly__t46_anpo-1-2_sn is a node-based surface used with surface to surface approach. In order to obtain improved stress accuracy with this approach, an element-based surface should be used instead.
麻烦各位指点一下该如何解决,不胜感激
CAE从业者
